9 members (Charles in CA, dt235sd, jmoore, Jay R, Southerntruck, Flatblu4748, tclederman, 5cameo8, 1 invisible), 72 guests, and 3 robots.
Topics128,128
Posts1,056,683
Members48,452
I want to replace the liner in the division bar attached to the vent window assembly. This is the liner for the front edge of the door glass. It looks like I have to drill out the rivets that hold it in. If so, can I just glue in the new liners or should I replace the rivets?
The rivets are not that hard to replace but you will need an assistant to hold it still while you set the rivets. You will need to remove the assembly from the door to do the job.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Moderated by  ndkid275, Phak1
