7 members (Joe H, KEVINSKI, baldeagle, kades51, DennisM, Jon G, JW51),
45
Mod | | | Forums66 Topics128,004 Posts1,055,247 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 55 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 55 | I want to lower my 51 3100 just a little more in the front. Right now I have about 4 leafs in the front I want to go down another inch. I don't want to pull a leaf. cause it will sit on the frame thats why I add a leaf to raise it so I still have suspension. Could I flip the eye making it a reverse leaf spring? Would it work or what r my options to lower my truck another inch without removeing a leaf | | | | | Joined: Feb 2012 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 96 | Won't solve the problem there is only so much room between the frame and the axle. If it's hitting the frame and you want to lower it more it's time for drooped spindles. | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | lowering front axle if you dont have one yet. available from many parts houses.
MO's 1951 chevy 3100 resto mod project
