2 members (lumbersawyer, Gray_Ghost), 85 guests, and 3 robots.
Topics128,050
Posts1,055,751
#845280 04/20/2012 5:35 PM
V
V Offline
1957 , removed most of the dull original finish used to reduce sun glare, primered, painted, both with rattle can and get a course finish in areas like sandpaper. Done a few times and can't seem to get a smooth finish. I am using a metallic color. Anyone know what I am doing wrong? Thanks to all for your input.
'57 3200
vhpeddler #845352 04/21/2012 12:02 AM
Ex Hall Monitor
Ex Hall Monitor
What grit sandpaper are you using?
Tiny #845410 04/21/2012 4:07 AM
Are you sure the top coat is compatible with the primer?
Are you allowing the primer to flash or dry long enough before covering it? Are you applying the paint too thick?
All those issues can cause problems similar to what you describe.
Chuck
what Tiny said - you need to use a good sanding primer and finish it with very fine grit before painting - and maybe do some color sanding if necessary .... metallics are picky about very good prep work
Flxible #845446 04/21/2012 3:39 PM
I believe its recommended that you get to 600 grit for flakes to be happy...
Give me ambiguity
or give me something else
Tiny #845701 04/22/2012 3:43 PM
V
V Offline
600 grit, thanks to all for your input.
'57 3200
600 grit is excessive and does not provide good "tooth" for paint adhesion. 320 grit is sufficient if done thouroughly and properly.
DavidF #845765 04/22/2012 6:15 PM
here's an quick thread about grits and dry vrs wet sand paper.
320 dry vrs 400 wet
and there is this one as well
Ready to spray paint
Give me ambiguity
