| | | Forums66 Topics128,034 Posts1,055,536 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | It seems I heard that a 216 bell housing won't work on a 235. Just wondering if anyone can tell me if this is correct or not. A friend of mine is going to replace the 216 in his '49 1 ton with a 235 and I told him I thought he needed to change the bell housing, too.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The clutch-housings interchange on 216s, 235s, and 261s.
However, if you have a 1953 or earlier truck, you want to use the 1953 and earlier truck clutch housing (rear motor mounts are different). 1954 and later trucks use the later-style truck clutch housing.
Other people might know what year car and truck clutch housings interchange.
You should also use a 6v or 12v flywheel that matches your electrical system (that matches your starter 6v or 12v). Then, choose a clutch assembly that matches the year/clutch-size of the flywheel. Buy the clutch-assembly parts together because there are different sizes (lengths) of throwout bearings. A pilot bushing/bearing usually comes in the assembly-kit - use it.
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | 1954 up,the bellhousing was different at the mounts.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
