6 members (Lightholder's Dad, Christian, baldeagle, Wickedbass, NJC, Hotrod Lincoln), 60 guests, and 4 robots.
Topics128,017
Posts1,055,338
Members48,419
#845150 04/20/2012 3:08 AM
Does anyone know if there is a secret to installing the shift knob onto the shifter.
I have an automatic on the column.
New shifter rod,
New shifter knob,
And don't want to destroy the new parts.
Assuming it's a stock plastic knob, soak the knob in hot water to soften the plastic. Than take a rubber mallet and hammer it into place.
I did mine in the '72 without soaking, but I imagine letting the plastic get hot and soft will help matters.
Jeff
My 1953 Chevrolet
1947.1 Gallery
I agree with rustednuts, and I would add a little Go-Jo, or equivalent for lube. Good luck!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
If its a slip on, hairspray makes it slip and once it drys, helps it stick. Old trick for motorcycle grips.
Well I finally got it on.
Turns out it follows aftermarket practice. The hole in the knob was not drilled all the way through at the correct size. It never would have gone on.
Once I drilled the hole to the proper depth and size I put the knob on as far as it would go and then put it in hot (140 degrees) water for about 5 minutes. It then went on with a few smacks of my mallet.
By the way I did not dunk the knob all the way in the water. Only up to the lip. I did not want it to fill up with water.
