11 members (David Bush, msmall, Southerntruck, Tyler Watts, Hush, JW51, Hotrod Lincoln, jasrking, Joe H, Gray_Ghost, Forty9),
105
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 35 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 35 | I'm working on the tailgate of my '58 Fleetside. The panel that says "CHEVROLET" has spot welds around it and I'm wondering if I should fill the spot welds as I'm filling the rest of the dents in the tailgate or were the spot welds visible when the truck came from the factory? Also, should I use seam sealer going around that "CHEVROLET" panel within the tailgate?
Thanks for any advice.
Steve | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | your choice, the factory didn't do it, what you see is the way they painted it, they were making working tools not museum pieces  Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I agree with Bill, but I'd state it like this: your choice, the factory didn't do it - what you see is the way they painted it. An original, untouched truck, which would be a valuable museum piece, would not have filler/sealer in those places. However, I have seen a 1948 GM Heritage Center truck - the GM restorers did not restore to original appearance. Heck, GM does not even know how to properly describe it: 1948 Chevrolet 3600 Canopy 3/4 Ton Truck. | | | | | Joined: Jan 2011 Posts: 35 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 35 | Thanks, guys. No filler it is!
Steve | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I asked the same thing awhile back, and went without filler. Looks good with those spot welds. I could see if the rest of your truck is custom that you would want them to disappear.
| | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | i filled mine - it looks great and i am glad i did it. So - another vote for "your choice" tailgate tailgate letters | | |
