9 members (48jim1ton, Gdads51, Forty9, Hotrod Lincoln, gswbbc, frogfarmer, Wayne67vert, sron48, dt235sd),
75
0
Mod | | | Forums66 Topics128,043 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | I know this is a basic question but what's the difference between the two? | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | 3100 = 1/2 ton short box 3200 = 1/2 ton long box | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Larry Maybe you know already but 55-2nd series was first 3200's. Your link did not work, but I went to the home page and saw a gray 55.2 or 56 Chevy step-side. Is that the truck? Looks like a short-box (3100). Nice truck!
Professional Novice
| | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Thanks Frank. I had someone crash into her last month... now trying to decide whether to buy another one because Lucille has a bit of body rot.... | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | How much longer is the Long Box (3200)
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 3200 bed is 8 feet, and the WB of the longbox is 123" compared to the 114" shortbox
Bill | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | 3200 bed is 8 feet, and the WB of the longbox is 123" compared to the 114" shortbox
Bill Actually 1955-1956 long beds are 89 inches, while 1957-1959 longbeds are 98 inches. The wheelbase is the same for 1955-1959 longbeds. The extra length on the 57-59 longbeds is behind the rear fenders. | | |
