9 members (warlock, Otto Skorzeny, 55shaker, k2handyman, RoadsScholar, Ponchogl, 5 Window 9434, 6inarow, 1 invisible), 97 guests, and 2 robots.
Topics128,048
Posts1,055,626
#84534 10/21/2007 4:53 PM
I have to replace the seal on the ball collar for the front u joint. During degreasing and disassembly I found a grease fitting on top of the u joint housing on the transmission. What type of lubricant should I use, and how would I know when I've pumped in sufficient lubricant since it is a sealed assembly? I have the bushing style of front u joint.
#84535 10/21/2007 11:14 PM
Hi Jim,
There would have originally been a small bolt where that grease fitting now is. This is the filler hole for the initial lube.This area receives it lube from the gearbox, however when its put back together you need to add about a cup of the same oil as is in the gearbox to lube the u-joint.
Cheers
Bob
#84536 10/22/2007 9:12 PM
Jim;
Do a search on this question. It has been brought up before. My fornt joint also has a zerk fitting and I lube mine with grease. Others have done this as well.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
#84537 10/22/2007 9:27 PM
Mozzie is right. I could be wrong but don't know if I would want to put grease in that area. It all mixes up with the transmission fluid.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#84538 10/23/2007 12:37 PM
I used a small amount of grease as a prelube. The rear of the tranny has a cast carrier that allows some tranny fluid to enter the ball housing for lubrication. The rear housing can be filled through the opening as Mozzie stated.
