2 members (carbking, TUTS 59), 108 guests, and 2 robots.
Topics128,029
Posts1,055,416
Members48,422
#845034 04/19/2012 10:06 PM
I have a switch for control of the heater. It has a 12 volt bulb and two wire connections on the back of the switch. I have one wire coming from the fuse box and another wire coming from the heater blower motor. Need some help. Which wire goes to which connector screw. Thanks for the help.
Larry
heater switch 1
heater switch 2
DADS50, thanks you for the picture. It is a great help.
Larry
Just finished wiring the switch. The switch works. The switch has 3 speeds. When it is on high position, the light comes on. Is it normal for the switch to get hot. After running the blower a few mintes in each position, I felt the back of the switch and it was hot. The truck is 12 volts and the switch is a 12 volt switch. I have it fused with a 10 fuse.
Larry
The light should come on with all three speeds. Mine gets brighter on the higher speeds.
Mines get hot also.
Thanks. again.
Larry
