1 members (78buckshot),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | I can't seem to find what the bolts for my pressure plate should be toqued to in any of the manuals. It is out of my 45 chevy 1.5 ton truck. It is a 9 hole P.plate with a 10 3/4" disc. Anyone know how many ft. lbs. these bolts should be torqued to?
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy sleeve, I did try to look it up, but I couldn't find it, my memory says 25ft.lbs., hope that helps. | | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | Thanks 3B ! The motor and clutch went in the truck this morning after my last visit to Stovebolt forum. I did a hail Mary play and torqued them all at 40 FT LBS. None of them snapped so I'll probably be alright. I don't have the scatter shield or transmission bolted up yet so I suppose it wouldn't be that hard to re-do them at 25. I guess I'll sleep on it.
| | | | | Joined: Feb 2004 Posts: 29,818 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,818 | They're 3/8"-16 Grade 8 bolts. 30-35 Ft./Lb. should be about right. Jerry
