3 members (DadsFirstPickup, Hotrod Lincoln, Otto Skorzeny), 163 guests, and 1 robot.
Topics128,131
Posts1,056,722
Members48,454
Custom Title
Custom Title
What thread is on the back of the factory AD oil pressure gauge?? I have a whole mess of fittings here and none of them fit. How does this work?
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
you need the double compression fitting.It fits the oil gauge and you need one at the engine block.Here is the link to the part you need. double compression fitting
Tim
1951 3100 Chevrolet
Had a whole bunch of fittings on mine when I bought it too. The oil guage thread size is 1/16" NPS. It has 27 threads per inch, the same as an NPT thread, but the oil guage boss is a straight rather than taper thread.
Stuart.
Interesting that the weblinks show a 5/16" by 24 thread. I used an optical comparator on my guage thread, it definitely pitched at 27 TPI. 1/16 NPS is near 5/16" OD and a 5/16 UNF 24 TPI nut probably wouldn't bind over such a short distance of thread whichever is actually on the oil gauge.
I just put my gauge on the threads of an original double compression fitting and it is #24 thread.
Tim
1951 3100 Chevrolet
Custom Title
Custom Title
So all i need is that nut from Weatherhead? How does that grab the copper tubing?
49 Chevy 3600
65 Chevy K10
The nose of the fitting crushes around the tubing as it's tightened.
regards,
Leon
I just screw the fitting into the oil gauge by hand,then slip the oil line tube into it until it stops.Then I tighten the compression nut making sure the oil line does not move while tightening.
Tim
1951 3100 Chevrolet
Custom Title
Custom Title
Oh, ok. That's easy enough!
49 Chevy 3600
65 Chevy K10
Originally Posted by bowtietim
.............nut making sure the oil line does not move while tightening.
Thought mine didn't move, guess I was run. Knew I was wrong when after the engine was running I noticed a 1/2 cup of oil on the ground under the runningboard and in the cab - what a mess! Removed the Guage and re inserted the tube, made a mark on the tube this time and kept a close eye on it while I tightened the nut...no problems now
....David
Custom Title
Custom Title
Maybe I'll pick up 2 nuts... lol
49 Chevy 3600
65 Chevy K10
