0 members (),
85
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 9 New Guy | | New Guy Joined: Aug 2009 Posts: 9 | Hi There!
Hope you fellow stovebolters can help me. I purchased a 57 chevy 1/2 ton stepside. 235 engine. It has the canister filter hooked up. The truck appears to be all original. I recently detailed the motor and went through a full tune up. I have a few other toys, but this is the only one that has the canister oil filter actually installed. So I wanted to replace the oil cartridge. When I opened the filter it had a cartridge that looked a little short and not wide enough for this canister. The cartridge had the manufacturer and part number: carquest 85076.
I ran that name and number on google.com and found that napa auto parts carried a filter with the same specs napa part number FIL 1076. I figured what the heck, I could live with this cartridge even if it was incorrect. I hit a snag though, when I went to replace the round rubber gasket with the one that was supplied with the new cartridge it was too short and caused the canister to leak oil bad. I ended up putting the old gasket and the leak stopped. I know this gasket is not going to last forever. I need to find out what canister my truck came with so I can buy the correct cartridge and gasket.
Your help would be greatly appreciated.
Sergio | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | get a measurement from your can and compare to Purolator L30034 for a fit
Bill | | | | | Joined: Aug 2010 Posts: 6 New Guy | | New Guy Joined: Aug 2010 Posts: 6 | I use the Napa 1100 cartridge in my ac Delco canister on the 55,fits and seals nice. good luck | | | | | Joined: May 2008 Posts: 20 New Guy | | New Guy Joined: May 2008 Posts: 20 | I have 5572288, AC P-115, and Wix 51100 unless you hae the 2 qt filter, that would be 5572425 or AC P-117.
59 GMC rare fleet option stepside pickup 57 Chevy sedan delivery 57 Ma Bell windowed panel (gone) 57 Ma Bell 150 sedan (gone) 57 Burb with p/s, Apache Res. school bus (gone) 56 Navy 3100 pickup (pieces) 56 windowed sedan delivery (US Dept. of Ag.) (gone) 55 Navy 150 sedan (gone) and many others now gone Founding father Desert Classics 55-57 Chevy club now gone
