3 members (Joe H, Bill Hanlon, Phak1), 118 guests, and 3 robots.
Topics128,127
Posts1,056,681
Members48,452
Hi There!
Hope you fellow stovebolters can help me. I purchased a 57 chevy 1/2 ton stepside. 235 engine.
It has the canister filter hooked up. The truck appears to be all original. I recently detailed the motor and went through a full tune up. I have a few other toys, but this is the only one that has the canister oil filter actually installed. So I wanted to replace the oil cartridge. When I opened the filter it had a cartridge that looked a little short and not wide enough for this canister. The cartridge had the manufacturer and part number: carquest 85076.
I ran that name and number on google.com and found that napa auto parts carried a filter with the same specs napa part number FIL 1076. I figured what the heck, I could live with this cartridge even if it was incorrect. I hit a snag though, when I went to replace the round rubber gasket with the one that was supplied with the new cartridge it was too short and caused the canister to leak oil bad. I ended up putting the old gasket and the leak stopped. I know this gasket is not going to last forever. I need to find out what canister my truck came with so I can buy the correct cartridge and gasket.
Your help would be greatly appreciated.
Sergio
get a measurement from your can and compare to Purolator L30034 for a fit
I use the Napa 1100 cartridge in my ac Delco canister on the 55,fits and seals nice. good luck
I have 5572288, AC P-115, and Wix 51100 unless you hae the 2 qt filter, that would be 5572425 or AC P-117.
59 GMC rare fleet option stepside pickup
57 Chevy sedan delivery
57 Ma Bell windowed panel (gone)
57 Ma Bell 150 sedan (gone)
57 Burb with p/s, Apache Res. school bus (gone)
56 Navy 3100 pickup (pieces)
56 windowed sedan delivery (US Dept. of Ag.) (gone)
55 Navy 150 sedan (gone) and many others now gone
Founding father Desert Classics 55-57 Chevy club now gone
