3 members (Hotrod Lincoln, MickeyP, Brian Moore), 44 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#8425 05/01/2005 1:01 AM
Anyone running a split exhaust manifold by kansas kustoms? #1 how does your truck perform with the split manifold? #2 what kind of mufflers do you run? #3 where do you have the other pipe cross over? thanks .old navy 51.............
#8426 05/02/2005 4:06 PM
Old Navy,
The Kansas Kustom manifolds are well made and reasonably priced. Smithy's blue mufflers come in 3 lengths. In my opinion the middle length muffler sounds the best, 30's are too long for the traditional sound. You will also get different Smith's sounds if you turn the mufflers around. If you want the triditional 6 cyl rap sound do not install a crossover. If you want it quieter use a cross over. The best place to put in a crossover is just past the crossmember where the brake line crosses over. I've also noticed that the cross over will help hold up the pipes if you ever have to take the Manifolds off. On your question about gas mileage: watch the size of your pipes from the manifolds to the mufflers, 2" or 2+1/2 inch pipe will give you less backpressure and also less mileage. Your engine needs a little backpressure. Its hard to find but look for nothing larger than 1+5/8 or 7/8th from the manifolds to the mufflers. From the muffler back you can use 2" or larger. Some research and google search under "header design" will give you some more background. Have fun.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
#8427 05/02/2005 5:29 PM
8
8 Offline
I have one and love it. I wanted to use the Smithy's, but didn't want the fuss of mail ordering them, so I went with a set of 24" glass packs from the local muffler shop and 2" pipes all the way back. It has a nice sound at idle, and just tooling around, but when you open the throttle wide at around 2000 rpm's, look out. She really talks. I can't say much about performance, because I installed them at the same time I installed the rebuilt 235. My pipe crosses over under the tailshaft of the transmission. The transmission drain plug misses the pipe, and also the u-joint ball. If you would need it, I could see about taking a picture, just let me know.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#8428 05/03/2005 9:51 AM
Hey Tim, nice truck. wink
#8429 05/03/2005 10:05 AM
Mike Yoder of Kansas Kustoms did one for me and it`s great!
You gain some power and milage with the split and some more with glasspacks.
California Bill said it is worth 10 hp compared to the stock (stuffed) muffler and exhaus system.
I have two cherry bombs that are a bit loud but sound sweet like a WW2 fighter plane is riding the rear bumper ;-)
I would prefer Smithy's, but it`s hard to get them over here.
Paint the pipes with cheap paint (spray can) and drive around for half an hour.
Place the crossover where the paint is not burned away.
have fun, Frank
#8430 05/03/2005 1:33 PM
8
8 Offline
Thanks, BelairBolt.
-Tim
#8431 05/03/2005 6:18 PM
Someone please explain the advantage of having a cross-over besides the quieter sound that 52pu mentioned.
#8432 05/03/2005 11:17 PM
Thanks for all the help guys, i'm going to go for it. old navy 51.............................
#8433 05/04/2005 12:06 PM
The reason a crossover reduces the sound is the various exhaust pulses from each side of the exhaust caxles eachother out at the crossover.
#8434 05/04/2005 6:00 PM
Cletis
Search crossovers here and you will find a much more detailed thread. Long and short, crossovers change the sound and can improve the breathing at certain RPMs, depending on type and location. The exhaust moving at the crossover can help pull exhaust out of the next cylinder (improved scavanging I think it's called).
#8435 05/05/2005 12:42 AM
Thanks for the suggestion, Highflyer. I found some really informative entries. One of the most interesting was this report.
#8436 05/05/2005 6:01 PM
8
8 Offline
Ok. Even though nobody asked, here is a link to a few pics of my dual set-up with manifold from Kansas Kustoms. My duals
I just want to show them off. grin
-Tim
#8437 05/05/2005 6:29 PM
nice looking eng.bay,,, duals sound good too..
Redryder pix
My Hotrod
#8438 05/05/2005 6:44 PM
8
8 Offline
Thanks. Just don't look at where my Rochester leaked all over the intake. :mad:
-Tim
#8439 05/05/2005 10:11 PM
Thanks for the pictures fab 51,looks great, old navy 51.......................
#8440 05/06/2005 7:23 AM
Hey, when talking exhaust, is it "Duals" or "Dooooooolllssss"?
