3 members (N-man, klhansen, 3800GUY), 121 guests, and 1 robot.
Topics128,131
Posts1,056,724
Members48,454
When I rewired my 52 1/2 ton several years ago, I installed new terminal blocks on the fenders. I don't remember who I bought them from, but they haven't done well. They seemed to have swelled up and are falling apart.
Does anyone know who sells a good quality terminal block?
My dad always told me, "Don't force it, get a bigger hammer".
3B Offline
Hy BillyDon, if you want the stock appearing ones, there are many vendors to choose from. If you want a quality part, then Cole Hersee p/n 4721-P3 (3 stud), p/n 4721-P4 (4 stud), hope that helps.
I'm more interested in quality. Will the screw holes line up with the existing holes in my fender?
3B Offline
Hy BillyDon, I have no idea on that, but here are the center to center measurements, 3 stud mounting holes are 2.5" apart on center, 4 stud mounting holes are 3.12" apart on center, hope that helps.
I work part time restoring vintage military planes. We have boxes full of used surplus terminal blocks and the are all Mil Spec. Have 3 on my truck. Check out a wiring shop at your airport, they must have used ones.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
I ended up buying them from Jim Carter. From their pictures, all the other vendors seem to sell exactly what I already had. The ones from Jim Carter seem to be made from more of a resin-based material (like a circuit board). Hopefully these will last longer.
