8 members (klhansen, Shade Baby, Shaffer's1950, JW51, Cosmo, Oswald, 2 invisible), 57 guests, and 4 robots.
Topics128,075
Posts1,055,919
Members48,429
#843820 04/14/2012 7:31 PM
I'm somewhat new to this stovebolt stuff so here goes my question. When changing the oil in my inline i remove pan plug and remove filter from canister only to have about one quart of oil left in the canister, why does this oil not drain down and out of the pan? Whats the best way to get this oil out?(short of taking the line free) Thanks for info as always!! headscratch eeeek
Suck it out with turkey baster or with a Sludge Siphon.
thats exactly what i did Tim. Now i have to replace the wife's baster!
The drain hole in the center tube is only about 1/16" in diameter, and it's halfway up the tube to prevent the filter from draining completely and delaying oil pressure buildup when starting. Even if you remove the return line the canister won't drain. The suction gun is your friend! Some canisters did have a drain plug in the bottom, but not all of them.
I now see what you are talking about....i'll check into a suction gun asap. Thanks.
