| | | Forums66 Topics128,078 Posts1,055,939 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 66 | I'm somewhat new to this stovebolt stuff so here goes my question. When changing the oil in my inline i remove pan plug and remove filter from canister only to have about one quart of oil left in the canister, why does this oil not drain down and out of the pan? Whats the best way to get this oil out?(short of taking the line free) Thanks for info as always!!  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Suck it out with turkey baster or with a Sludge Siphon. | | | | | Joined: May 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 66 | thats exactly what i did Tim. Now i have to replace the wife's baster! | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | The drain hole in the center tube is only about 1/16" in diameter, and it's halfway up the tube to prevent the filter from draining completely and delaying oil pressure buildup when starting. Even if you remove the return line the canister won't drain. The suction gun is your friend! Some canisters did have a drain plug in the bottom, but not all of them. Jerry
| | | | | Joined: May 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 66 | I now see what you are talking about....i'll check into a suction gun asap. Thanks. | | |
