2 members (papas52, carbking),
69
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 88 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 88 | OK, I'm installing my heater and I've tried hooking up the defroster hoses but I can't get the drivers side hose to go on because it has a rubber sleeve on it...at least it was rubber 60 years ago. I've got a parts truck and it's the same...it has a sleeve on the drivers side but not on the passenger side. Does anyone know why the drivers side defroster has the rubber sleeve but the passenger side does not? Is this just a leftover from an old hose assembly? | | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | I know some things changed in 54, and that's what I have, but there was no sleeve on either of the vents. Just a cast metal part. Might be leftover hose like you said
....David
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Jim Carter sells the sleves, but for a later model. Probably would work for you if you decide to go that way. I didn't and just used tie wraps to hold the hose on the vents.
Drew
| | | | | Joined: Aug 2008 Posts: 88 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 88 | The sleeve is not moving and wouldn't funtion as a grasp for the hose...tie wraps are a good idea. Thanks for the info | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Just my theory about the rubber sleeve on one side, although yours sounds reversed from my truck ...
The hose inlet on the drivers side defroster deflector at the windshield on my '54 3100 is larger than the diameter of the deflector on the passenger side. The two outlets for the hoses on the heater body are the same diameter. If a larger hose is used on the drivers side, then a rubber sleeve must be put over one of the outlets at the heater to increase its diametet to match the larger heater hose on that side. A larger hose may have been used on the drives side because it is longer than the hose on the pasenger side and would therefore have more total resistance to the air movement.
Or maybe someone just screwed up and put the wrong size deflector on the drivers side of my truck??
The sleeves are shown in the Accessories Installation Manuals for various years. Although I believe that their number and locations may be different for different years.
By the way, I have a rubber sleeve for one of the outlets supplying air to the drivers deflector, but haven't put it on yet or installed a larger hose on that side. So for now, both hoses are the same diameter. I jammed the defroster hose inside the large inlet on the drivers side, and fitted it over the small inlet on the passenger side. The hoses fit on the heater outlets without sleeves.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Lonnie, Compare this illustration to the analogous illustration in the 1954 Accessory Installation manual. The 51 shows equal diameter hoses and fittings. The 54 shows different diameter outlets on the deluxe heater and on the under-dash inlet fittings. It also refers to the bushings used on the driver's-side heater outlet and on the driver's side inlet adapter under the dash. I'll post images later today, if needed. ADspudnut, what style heater do you have and what year is it? We can help you answer those questions if you can give us a good photo of the front of the heater box/unit. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Thanks Tim, I have the '54 diagram in my '54 Accessories Installation Manual. My truck has a larger inlet on the drivers deflector, so a bushing is not needed with a larger hose. Only need one bushing -- on the outlet at the heater. Both defroster deflectors look original, but who knows.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2008 Posts: 88 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 88 | Interesting...I knew there had to be some science behind that bushing on the deflector. I have a '53(maybe) fresh air heater. Both outlets are the smaller size. I'll check the numbers on the heater and take some pictures tonight. | | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | My '53 recirculating heater takes a 2" diameter hose on the driver's side and an 1 3/4" hose on the passenger side. The dash vents on both sides are the same size - 1 3/4" and that's why the driver side uses a rubber adapter so the 2" hose will work. Chevy's of the 40's sells both size hoses in the original type fabric. | | |
