| | | Forums66 Topics128,203 Posts1,057,286 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I rebuilt the column mounted shift box on my '51 3100 last night and I was wanting to replace all of the bushings in the linkage from the box to the trans... How many are there and where can I find them? My truck has these odd spring/washer things at all the pivot points and seeing as my trans mount is a chunk of tractor tire and there's a hand snipped galvanized shim in the shift box, I'm thinking these also may be a vintage shade tree fix. So far for the 47-55 all I can find are the two at the box arms. 1951 column shift box pix for those stumbling across this while searching for stuck or jammed three speed column shifters. Just cleaning the box out and re-greasing everything made a HUGE difference. http://farm6.staticflickr.com/5111/7069517703_8f72b76b80_b.jpghttp://farm6.staticflickr.com/5451/7069518273_095cbc3566_b.jpg | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | After a bit of digging and a few phone calls I found em! The linkage grommets are pt# HRN-23 (1948-1966 Shift rod grommet, with metal lining) at American Classic *Note: They don't come up in a normal search for transmission or shifter parts like the box arm bushings do. The 47-53 requires six of them and the 54-55 gets four. For those rebuilding the whole box, you'll need these parts too. CB803 (1947-1959) Column shift bellows SLRB4 (1947-1959) Shift lever rubber bushing pair | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | From another thread so as not to hijack... BLUEMEANIE,
Not to hijack, but thanks for posting this. I am thinking about diving into mine (57 3100) soon and this will help a lot.
Can this work be done with the column in place? Or do you recommend pulling it before cleaning out the shifter box? I will need new bushings and likely the rest of the parts too.
EDIT...and the kerosene was for cleaning the old grease out, yes?
Thanks again,
Jim Yep. Kerosene and a spoon. The steering column stays in place as does the top half of the shifter column/rod. There are two bolts on the back side of the shift box and a coupler on the rod inside the cab near the firewall. Undo those and the box can be removed. I opened it up before removing it and had a friend shift thru the gears so I could see how it worked and where it hung up. They're amazingly simple. Before you get the whole thing pulled apart, pay attention to how the spring sits when you pull the top off. You might also need a helper to hold things in place while you reassemble. Inside I used a good coat of blue Lithium grease from Autozone. You don't need to glop it on either, just coat everything. I think its intended for wheel bearings, suspension & universal joints but I use it on everything from bicycle parts to blow off valves to adjustable coilovers, swaybars and other suspension parts. This is similar (mine has been in a Grey Poupon jar for years) - http://www.bcf.com.au/online-store/...artridge-450g.aspx?pid=89002#Description | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you don't really need to take the box off the column, start with taking the top off the box and it can likely be cleaned out quite well in place and most parts can be replaced without disturbing the adjustment of the trans control rods, just by lifting the fork assembly out of the lower box half - a '57 box for assembly reference, and more pics in that album Bill | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | red58, mine was so packed full of grease and gummed up that it had to be removed. There was also a lot of foreign crud in there I could only get out by fully submerging it. It literally looked like someone packed both halves completely with grease and sandwiched the innards then continued to top it off over the past 60yrs. Now that I have an appropriate amount of grease in there, next time I can simply pop the top, wipe it down and re-grease. In my opinion, if this is the first time its been done that you know of its probably a good idea remove it and clean it completely.
As far as adjustments, other than getting the shift lever where you want it, you're only pulling the cotter pins out at the bushings so nothing should need any tweaking unless the clamps were out of adjustment to begin with. ...in which case you'd need to do it anyways.
Besides, removing it was such an easy process that I can't see why you'd skip cleaning it completely if it needs it. My shifter moves and springs back so freely now. I can only imagine it'll be like new with all the bushings and grommets replaced. | | | | | Joined: Dec 2011 Posts: 402 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 402 | Thanks very much for the details. Right now, mine moves, but with a bit of a hitch. In neutral, and between the two "legs" of gears, it feels (on the shifter) like there is an elevation change between the legs. As in, when moving from neutral point between Reverse and 1st and moving "forward" to the neutral point between 2nd and 3rd, I have to elevate the shift lever slightly.
I am hoping cleaning and bushing replacement will cure this. I have never tried the kerosene trick, so thanks for that.
Will keep you posted. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I clean all greased bare metals w/ kerosene and a soft wire brush.
I've noticed that when I push up, out of first and I let the lever guide itself to neutral as I push into second it tends to jam. It seems that the "tab" on the rod that moves the "legs" inside the box slips between the legs of the R/1st lever and the legs of the 2nd/3rd lever. If I pull the lever toward me as I shift out of 1st and, once in the neutral position, let the spring pull the lever back before pushing up into second its flawless. Shifting this way may seem a tad clunky but you get use to it and things become second nature.
If you take the box top off before removing anything else and have someone shift it so you can see whats happening, it will make complete sense. You'll also get an idea of where its jamming and what you can do to fix it. ...someone added shims to mine to push the arms closer together so the tab wouldn't slip between the leg pairs as easily. Now that its adjusted properly, it doesn't need the shims.
[edit] ...after re-reading your post it seems like your arms need to be adjusted. Once you've cleaned, greased, reassembled, reinstalled the box and connected the column rod, reconnect the linkage to the arms and loosen the clamps. With the shift box top off you can realign the arms so the tab moves freely between the leg pairs (have a helper move the shifter back and forth in netural). Once everything is aligned, tighten the clamps and put the box top back on. | | | | | Joined: Dec 2011 Posts: 402 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 402 | Great! Thanks again BLUEMEANIE. I think that's just what I needed. Will post after I get the bushings and have it reassembled (won't be for a couple of weeks at least).
Best,
Jim | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | No problem! Let me know if you have any questions.
I'll need to take it off again to putt the rod bellows on so I'll probably photograph the process and post it all as a tech tip with step by step instructions. | | |
