0 members (),
75
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84339 10/15/2007 4:27 PM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Does anyone recognize this air cleaner and do you know what vehicle it might be off of?? It’s a single barrel clamp on type and it fits the Carter W-1/YF and early Rochester ‘B’ carburetors. The clamp is tightened with a screwdriver although It may have had a thumbscrew at one time, hard to tell. http://rides.webshots.com/photo/2745152740098611668fUwngi I picked it up at a swap last week and plan to use it on my ’50, 216. I have been looking for the correct oil bath and this is the closest that I have come. The original option looks like it’s a little shorter than this one, has a smooth cover and has the extended thumbscrew. Denny Graham Sandwich, IL
Denny G Sandwich, IL
#84340 10/15/2007 4:31 PM | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I saw one very similar to that on a '50 or so Chevy car at the junkyard a while ago. | | |
#84341 10/15/2007 5:25 PM | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | Looks like the one on my pa-inlaw's 55 Ford Customline, Scott | | |
#84342 10/15/2007 5:43 PM | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Doesn't look like Chevy,at least 50's oil bath, because top hat would be inside of base I think. However,how many manufacturers did GM use for parts? My thought is if it fits and you like it,use it. And given the side cutout, I think it did have an extended thumb screw for tightening the carb clamp.
Drew
#84343 10/15/2007 8:18 PM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I should have included this picture or the option also, it's out of the Truck Data Book. Denny Graham Sandwich, IL
#84344 10/15/2007 9:15 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That was used on Chevy cars 49 up. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#84345 10/15/2007 10:12 PM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Denny, That looks like a Series 5000 truck air cleaner. I do not know what years that style was used (the picture at the link is for 1954 and says that there was some sort of change in 1954). The write-up also says that cleaner is "similar to the types used in the rest of the truck engines". You decide what the word "similar" means. If you look closely at the two pictures in your webshots, I think they are not the same height. Are the two diameters the same? Tim | | |
#84346 10/15/2007 11:20 PM | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Denny,
It looks just like the one on my 54. I don't know if mine is original, althought it fits the rochester. | | |
#84347 10/16/2007 12:53 AM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Boy that sure looks like the one Tim. I only have the one in the picture, I wish I had the one in the illustration so I don’t know if they are the same dia. And it does say that it is similar to the type used it the rest of the truck engines, which leads me to believe that it may be from a mid 50’s truck. So Lonnie, that may be the original optional oil bath on yours. Yes I know they are not the same height, that’s why I posted both the picture and the illustration of the proper one. Like I said, this base does fit all of the common 40’s and 50’s Chevy single barrel carbs, around 2 5/16”. I’ve been searching since I got the truck for the correct oil bath filter but haven’t run across one yet. I kind of doubt that the one I picked up was used on the cars. Since it is a taller unit than even the light truck option of the period it was probably intended for more severe service than what plain old highway driving required. Lots of good ideas guys, thanks. I wish I had something that showed all the optional equipment for the period in the mid 50’s. That illustration was from the ’54 Engineering Features wasn’t it Tim? Denny Graham Sandwich, IL
#84348 10/16/2007 1:15 AM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Denny,
Yes. that link is to a page scanned from the 1954 Truck Engineering Features manual. You can get to the table of contents by pressing the up-arrow in the linked-page and then press the up-arrow in the next screen.
Tim | | |
#84349 10/16/2007 3:41 AM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | | | |
#84350 10/16/2007 8:30 AM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not with a one barrel carb one it Beaver. I'm bout 95% sure Tim's got it nailed down. Denny Graham Sandwich, IL
#84351 10/16/2007 11:13 PM | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Denny, Looks like the one on my 51 Burb. Regards | | |
#84352 10/17/2007 1:07 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Denny,take a look at the photo links.The pictures are of an oil bath breather off of a 1951 chevy car,216 engine.It looks identical to yours. The very top is 9 1/8" diameter. The lower part is about 11 1/8" in diameter Total height together is 6 1/4" Carb hole is 2 5/16" diameter 1951 chevy car oil bath breather pic#1 1951 chevy car oil bath breather pic#2 1951 chevy car oil bath breather pic#3 Hope this helps in any way !!! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#84353 10/17/2007 9:23 AM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep Tim, that's the exact same one for sure. My only question is whether it came stock on that passenger car of whether someone added it? I seem to remember the early cars having a shorter oil bath filter. I had a '50 and a '51 and probably cleaned dozens or others when I worked in the gas station but danged if I can remember back that fur. Thanks for the pictures. Gotta say, this thing is a son of a buck to clean. the lower section is two pieces crimped together forming kind of a toris. It's only open in the throat. When you dip it in a solvent tank there is no way to get all the solvent out of the lower section, a couple of cups get stuck in there and all the sloshing around can't get it out. I ended up drilling two 1/8" drain holes in the lowest sections to drain out the solvent.
#84354 10/18/2007 4:50 AM | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | I just took another look at mine. It is the same as Tim's. The decal on the lid states to use a type 23 filter element. | | |
#84355 10/18/2007 11:15 AM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I don't see a decal on mine or your's Lonnie? I don't suppose you took a picture of the decal when you shot the rest, did ya Lon??? (ain't I a real pain in the ***?) Denny Graham Sandwich, IL
#84356 10/18/2007 5:47 PM | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Denny,
I did not post a picture of mine, but I can. I took some pics last night with the intent of posting them, but when I saw Tim's; it being the same, I did not post them. I will get a good picture of the decal and post it in the next few days. | | |
#84357 10/18/2007 10:38 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They originally came on the cars. The bottom is resessed for hood clearance & they have a silenceing chamber. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Denny, It has been a few days so I thought I should post this picture of the air cleaner decal. There are also four pictures in my build pics, under air cleaner. Air cleaner
