1 members (Hotrod Lincoln), 60 guests, and 0 robots.
Topics128,050
Posts1,055,641
So i just took my baby for her first testdrive down the block, came back and parked in the drive way. I popped the hood just to see how everything was doing and, my gas in both glass bowls are milky/cloudy...what caused this?? i know oil+water gives you milky oil, but i have never seen this with gas... any help greatly appreciated
3B Offline
Hy Josh_51GMC, that's great news about the drive! Did you clean out the whole fuel system, tank to carb? It sounds like you have some contamination in there. You might want to install a fuel filter in front of the fuel pump. Keep up the good work Josh!
Haha thank you, yes i did flush out the entire system. I just found it a little odd, i literally just took the truck off of jack stands and everything was fine while it was up. went to start the truck, out of gas, dump a jerrycan in, it starts right up, and the gas is gas colour. after the drive i pop the hood and it looks like milk... I've googled what can cause this they say:
Water - but it will most likely not mix
OIl - apparently back then people would dump a quart of some sort of oil in after each fill
Sugar - but then the engine wouldn't run
Or cross cantamination between 2 different fuel types....
Heres a pic of yesterday after the test drive, and what was in my filter bowl:
Milky
And heres this morning:
Seperated
It looks almost like elmers glue from kindergarten has settled on the bottom of the bowl....
maybe the fuel pump is bad and trading a bit with the crankcase - have you looked at and sniffed the crankcase oil?
Perhaps a Previous owner poured some cheap "gas tank Liner" goo in the
tank?
If so, the Corn-a-hol could be starting to work its magic and that liner material is sliding off into the fuel ..... Might be prudent to drop the tank and do a serious
physical inspection.
mike
I think Squire got it right,i just drained the tank, flushed everything from carb to tank again, refilled with gas in a new jerrycan, and same problem.
I took the sending unit out and took a look with a light and mirror inside the tank, its all milky. Im going to start dismantling the tank and pressure wash/cook it and see what condition it is in after that
Josh_51GMC -
This won't help your milky problem. But I believe that the spring in your fuel filter is upside down. The fat end sits on the glass bowl. The skinny end presses against the bottom of the filter element.
1952 Durex Moraine sales book. Hold Ctrl and tap + to zoom in to see spring position.
- Lonnie
My '54 3104
Thanks Lonnie, i thought it went that way sence the filter kinda fit into that end of the spring.
As for the tank, i pressure washed it for a good hour or so....the gunk.white slime coming out was disgusting. i dumped about 7L of tank cleaner my shop teacher bought me, hopefully a couple hours sitting, soaking, then shaking..repeat will clean things up further
If your cleaner doesn't get all the goo out, and it is old tank liner, you might try some MEK. Don't breathe the stuff though. S'not good for you.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Josh! I don't care if you ran MILK through that engine, you took your first ride!! Was it worth the wait?!?
Dads50: Hahaha i would if i could, but, being a high school student with a couple other projects going on, that has to stay on the wish list
Bigtonka: Was WELL worth the wait! I'm hopeful to have my tank issue done and back in the truck tomorrow, maybe time to go see what else i need to do to register this beast
