| | | Forums66 Topics128,180 Posts1,057,163 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I wasn't going to buy one, but I noticed the dings on the back of the cab on my 48 two ton are right where it is boxed in by the interior supports. I can't get a dinging hammer to it. So I am going to open up for the HF stud gun. It is on for $99 and I have a coupon for 25% off. For $75 and probably limited use, I'll go for it. I don't know how to get the dings out any other way. Don't want to drill holes. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jul 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 66 | Super55, You won't regret it. I tried mine on those cab dings last week with a lot of success. I'm trying to use as little bondo as possible. I was able to pull small dents so that only high build primer will be necessary. I borrowed some techniques from the paintless dent removal guys. Here's what I found that works: I polished the area so that I could watch the reflection while I pulled the dent. A fluorescent light works great for the reflection.
I only used a short pulse to weld the studs. The studs can be twisted off and reused a couple times.
Instead of using the slide hammer, I made a "bridge" tool. It's a steel bar with a small hole that is supported at each end about 3/4" away from the surface. The welded stud pokes through it and I pull it slowly with a pop rivet gun. Very controllable.
A dent the size of a quarter may require 8 pulls or more to progressively bring the surface up where it should be.
Use a sanding block to scuff it lightly to see if you have any high spots. Tap them down a little if necessary.
When you're satisfied, lightly draw file over the area.
Dave Evans 52_3100
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Hey thanks for the tips. I picked up the stud gun. I'll try your pop rivet tool idea. Sounds like a very good idea.
A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | Super, did they let you combine the 25% off coupon with the sale price?
Ed Miller '58 Apache short Fleetside half ton Napco Falls City, OR
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Oh no, if you read the fine print on those coupons they can not be used on welders, tool boxes... etc. All the big ticket stuff. I did read it before I went to the cashier, but she also brought that to my attention. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | So, are you going to come over and pull the dents in my fenders to practice Paul? | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | You should have just left it with me!
A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Hahaha! The old bus has had another 900 miles or so on it now. That's allot of walking! | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | I've got a HF stud gun and it works great. | | |
