| | | Forums66 Topics128,037 Posts1,055,470 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 24 New Guy | | New Guy Joined: Feb 2012 Posts: 24 | hi,im needing the rear emergency brake cables for my panel truck.i have the spring assembly and a cable and pulley for the front i think,im needing the rear cables,my question is will the ones for a longbed truck work,my truck actually has a 69 camaro positrac ten bolt rearend in it so im not sure where to go,thanks for the help | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if it's a 1/2T, the cables for a short bed are the correct ones - how you'll hook them up to a Camaro rear is a different question
Bill | | | | | Joined: Feb 2012 Posts: 24 New Guy | | New Guy Joined: Feb 2012 Posts: 24 | dang bill i figured you would have the answer :)thanks for the reply,i was hoping that a 69 camaro and 56 chevy/gmc would hook uo the same,shortbed truck huh,i figured the panel was longer,thanks | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Inlinetube can make them for you. inlinetube 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If the Camaro cable is close to reaching the "L" brackets on your Panel Ebrake bar, you can use a Dorman PN 21125 cable connector (google it) and attach the ball end of your Camaro cable to it and weld/attach a threaded rod to other end of 21125. The rod will pass thru the "L" bracket and be secured with nuts on either side as per original. You can, of course, make your own version of the cable connector to transition from a ball to a rod. I have not tried this yet and am not 100% sure it will work. I know it will apply the ebrake but not sure the spring on the ebrake end inside drum will maintain tension so as to keep ball seated in 21125 on the release. I think it will. I may be trying this, or a hybrid of this, in the near future on my 57 Panel with a 64 12Bolt.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2012 Posts: 24 New Guy | | New Guy Joined: Feb 2012 Posts: 24 | news update,the truck cables worked perfect,hooked up to the camaro rear end no problem,brakes are done | | |
