3 members (Otto Skorzeny, dt235sd, 2-Ton), 58 guests, and 2 robots.
Topics128,049
Posts1,055,661
#841839 04/07/2012 2:30 AM
hi,im needing the rear emergency brake cables for my panel truck.i have the spring assembly and a cable and pulley for the front i think,im needing the rear cables,my question is will the ones for a longbed truck work,my truck actually has a 69 camaro positrac ten bolt rearend in it so im not sure where to go,thanks for the help
if it's a 1/2T, the cables for a short bed are the correct ones - how you'll hook them up to a Camaro rear is a different question
dang bill i figured you would have the answer :)thanks for the reply,i was hoping that a 69 camaro and 56 chevy/gmc would hook uo the same,shortbed truck huh,i figured the panel was longer,thanks
Inlinetube can make them for you.
inlinetube
1951 3100 Chevrolet
Sir Searchalot
Sir Searchalot
If the Camaro cable is close to reaching the "L" brackets on your Panel Ebrake bar, you can use a Dorman PN 21125 cable connector (google it) and attach the ball end of your Camaro cable to it and weld/attach a threaded rod to other end of 21125. The rod will pass thru the "L" bracket and be secured with nuts on either side as per original. You can, of course, make your own version of the cable connector to transition from a ball to a rod. I have not tried this yet and am not 100% sure it will work. I know it will apply the ebrake but not sure the spring on the ebrake end inside drum will maintain tension so as to keep ball seated in 21125 on the release. I think it will. I may be trying this, or a hybrid of this, in the near future on my 57 Panel with a 64 12Bolt.
news update,the truck cables worked perfect,hooked up to the camaro rear end no problem,brakes are done
