0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | Steering problem on a 49 panel truck. Rebuilt and installed the steering sector but noticed that no matter how I attempt to position the Pitman arm the wheels turn further to the right, or passengers side, then they do to the drivers side, is this by design or is something out of adjustment. The difference In the number of turns on the wheel is about one full turn. Please, any thoughts on this, or is this the way they made it? Thanks for the help. Remember, Jesus Christ the Lord is Risen, as He said He would, and all who believe will rise in like manner! Happy Easter
God bless,
Dave
Joh 3:16 For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
| | | | | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 | Sounds like both the pitman arm and steering wheel are in the wrong location. Remove pitman arm and steering wheel. Place pitman arm on barely and turn all the way to one lock of the steering box. Then, count how many turns it takes to get to the other lock. Calculate where you need to be to "center" the steering box.
Set the front wheel parallel with the rear wheels and install pitman arm and draglink. Finally align the front end then install steering wheel. Keep in mind the steering wheel may need to be reinstalled a couple times.....
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The pitman shaft has four keys on the shaft spline and would be way off of if the arm was put on wrong. However you could have installed the pitman teeth in the wrong position in the worm nut. I have also seen pitman shafts with a torsional twist that gave a similar response.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | I thought about the the teeth in the worm nut, I dread having to pull the whole assembly to check and see if the teeth are wrong. As to the positioning of the pitman arm on the shaft, though there are four keys, and as I look closer at the spline it seems that the arm can only go on in one position because the keys are arranged such that it cannot be put on in another position. Am I correct or not? Please, further insight is greatly appreciated.
God bless,
Dave
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The arm can go on in one of four positions but the other three would make it imposable to use.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There are stops on the spindles that contact the axle. They may need adjusting. The main thing is to get the wheels straight ahead when the steering gear is in the high point. You can feel the high point by turning the steering wheel & feeling the drag. With the wheelsv off the ground or the pitman arm disconnected. Sometimes you can overadjust the sector adjustment temporarily to find the high point. If you get The gear box centered & the toe in correct you can remove the steering wheel & put it on center. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
