| | | Forums66 Topics128,006 Posts1,055,267 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 18 New Guy | | New Guy Joined: Feb 2012 Posts: 18 | Hello to everyone, i got excited today after i Easy Off oven cleaned my engine today i found some numbers stamped on my block and head, i was hoping someone can send me in the correct direction in finding the proper id for them. starting at the back of the block behind the starter it appears to be a- CF 19 4 then a- GM 8 Then 8764476
on the head the Starting from the front - 3836848 GM 2 and at the end of the head there is an M in a box | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Someone with information on Canadian GM codes will respond.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy stalker21, numbers that are raised above the surface are casting numbers, numbers that are flush with the metal have been stamped into the block and are usually an alphanumeric code to identify that particular parts original application. From Inliners International I found the following info, casting number from cylinder block 8764476 no record, however there is a casting number 3764476, which is a 1958-62 235, please recheck your casting number cylinder head casting number 3836848 is listed as being from a 1956 235, however it seems to be a consensus that this head was used on a lot of newer engines as well. Please remember to tell us what year and size of truck you're asking questions about in your posts, hope that helps.
| | | | | Joined: Feb 2012 Posts: 18 New Guy | | New Guy Joined: Feb 2012 Posts: 18 | It does and thank-you. i did forget to list my truck. it is a 1957 Chevy 3/4 ton dually, i will clean the area again and see if any more gunk comes off but i am sure it is an 8 and not a 3 for the block casting number. i do have pictures of the numbers i will try and add | | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | engine cast #s on my 235 are 3738307 and I,m told that it is a 58-62 engine. the head casting is the same as your,s Doug | | |
