3 members (FishinToms53, ShopRag, Stovebolt48), 90 guests, and 0 robots.
Topics128,049
Posts1,055,634
#840867 04/03/2012 3:11 PM
Hi from England
Got a problem i need help with please
ive a 54 AD with a 350 with a 1406 edelbrock carb.
When i park up i get a real bad fuel smell under the hood and in the cab, i wonder if the carb is over fuelling?
I have a standard pump but i do not have a pressure regulator on it
Do you think that my fuel pressure may be to high?
The truck runs well apart from a slight bog down on takeoff.
The tank is under the bed so i know it is not this
Will a fuel regulator possibly cure the problem?
Thanks Keith
if it ain't greasy it ain't diddly
english54 #840876 04/03/2012 3:59 PM
You shouldn't need a regulator with a standard mechanical pump - it will put out 5 or 6 psi which is OK with your Carb. I'd start by checking all your fuel lines / connection points / filter ( if you have one ) for leaks, then look at the carb. Edelbrock has a decent trouble shooting section in their on-line tech help section. Might also check your gas cap to ensure proper venting.
1940 Chevy KC 1/2-Ton
Britcon #840879 04/03/2012 4:28 PM
thanks for that, i cannot see any visable
signs of a leak, it only happenens when i have been out in the truck, and switch off when it is hot, i have a clear fuel filter which seems to show the fuel bubbling?
I
english54 #840891 04/03/2012 5:26 PM
It's possible that after you shut down, the carb is getting heat soaked and fuel is being pushed past the needle and seat ! Pull the air cleaner after shut down and look for excessive fuel in the carb.
helilog56 #840910 04/03/2012 7:22 PM
ok thanks, i have a heat dissapator kit would fitting this under the carb possibly
solve the problem, or what would be my next move.
regards
Keith
english54 #840928 04/03/2012 9:13 PM
might try some heat shielding to start, sounds you have fuel lines too close to hot spots, like the exhaust manifolds or the head
Flxible #841113 04/04/2012 3:01 PM
My 250 smells just like yours, after shutting off when hot. I just figured it was fuel evaporating off the intake floor. I an going to look into the problem more now that I think about the hot fuel line. Float level could be high as well, it wouldn't take much heat to raise the fuel level as it expands from a good heat soak.
Joe
Joe H #841195 04/04/2012 8:31 PM
Hi Joe
i think my next move is going to be putting a 1" heat spacer under the carb and check that all my fuel hoses are clear of hot spots.
I think it may be fuel bubbling in the carb because of the heat and passing through the needle and seat,
I will let you know how i get on, i should have it on this weekend
regards
Keith
english54 #841202 04/04/2012 9:01 PM
Keith,it sounds like you're on the right track.
More pix on Flickr.
