3 members (Hotrod Lincoln, 2-Ton, MikeE), 133 guests, and 3 robots.
Topics128,266
Posts1,058,385
Members48,485
Sir Searchalot
Sir Searchalot
It is a truck 12 Bolt 3:73 ratio. It has the big panhard bar bracket on pass side. Does this stamped number, which is on back side of axle tube on drivers side, tell year? WE 7 09
I just spent 2 days making a 64 rear axle fit a 65 because it had that big panhard bracket which I had to cut off. I can tell you for sure it's a 64 or older. The 64 housing also had WE stamped on it. The 65 had HC, both were 3.73's.
'65 C-10, 65 L-60, 65 C-80, 72 C-60 & and a bunch of old Chevy cars.
Never time to do it right, always time to do it over.
Sir Searchalot
Sir Searchalot
Found casting code N 3838227. Best I could find out is 63 and 64, 6 lug, had these style panhard bars and 63 has a pressed on backing plate and 64 has a welded. This is welded. I am trying to confirm this 1964 idea with the numbers. This is to get correct brake/axle parts. it seems like 64 and up stayed pretty much the same. HOWEVER! the 64 rear axle seal is $$$$$$$$$$$$$$. Can't find any other numbers/date code on it (yet). Thanks for the help Mearl, anyone else?
According to my chevy truck ID book WE is a 3.73 axle made at the Warren plant. It is for both 63 and 64. The 7 is the month it was made.Thus it is a july axle. The 09 is the day built. The distinguising facter here is where the stamped numbe is located. For 63 it says it is stamped on the bottom of the differential carrier housing just forward of the cover. The 64 is stamped on the the forward side of the left axle tube near the carrier housing. Hope this helps.
65 K10 Longbox Fleetside Big Back Window Custom Cab
65 K10 Flatbed
Old School Parts 60-66
(208)946-6173
[email protected]
Sir Searchalot
Sir Searchalot
Well it's on the left/drivers axle tube but on the aft portion. The work sheet could have easily changed during the year for some reason. I'm goin with 64. Thanks 66burb.
I'm having the same problem with the axle seal on the 64 axle I'm trying to put in Deb's 65. Had to special order it. I would say for sure now you have a 64 axle.
Sir Searchalot
Sir Searchalot
I found them on Amazon pretty cheap but they had only one left. They usually get more by and by.
