6 members (farmallb, ChevyBlue, 2-Ton, carbking, Hotrod Lincoln, tclederman), 144 guests, and 1 robot.
Topics128,089
Posts1,055,991
Members48,430
#840727 04/02/2012 11:41 PM
Hi
Thanks Rick I am connecting the 2 hoses that go from the motor through the firewall into the heater. I am not sure which hose goes to which side of the heater. Can anyone explain or show photo. Its a 235 in a 58 3600
Rick
58 3600 4 on the floor
deluxe heater > the outer tube [fender side] comes from the pump fitting, the inside tube [toward engine] goes to the head [or thermostat housing]
standard heater > the top [higher] fitting comes from the pump, the lower fitting goes to the head
Perfect
Thank you
Rick
Rick
