| | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Hi Thanks Rick I am connecting the 2 hoses that go from the motor through the firewall into the heater. I am not sure which hose goes to which side of the heater. Can anyone explain or show photo. Its a 235 in a 58 3600
Rick 58 3600 4 on the floor
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | deluxe heater > the outer tube [fender side] comes from the pump fitting, the inside tube [toward engine] goes to the head [or thermostat housing] standard heater > the top [higher] fitting comes from the pump, the lower fitting goes to the head
Bill | | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 |
