3 members (IHPWR, David Bush, Gdads51), 130 guests, and 3 robots.
Topics128,142
Posts1,056,472
Members48,441
Was wondering if anyone has a cable and or pictures of the cable for my 1957 Chevy suburban clamshell door.
A length measurement would be great too.
Lower clamshell hinge bracket repair
http://m1117.photobucket.com/albumview/albums/Theorangebomb/1333072948.jpg.html?o=2
Upper clamshell door installed
http://m1117.photobucket.com/albumview/albums/Theorangebomb/1333072954.jpg.html?o=0
Thanks Sean for the pair. !!!!
Jon
Hi Jon, Since I haven't seen other responses I'll give you what little info I have.
The actual cable looks pretty much like the tri-five Chevy wagon cables; (see Danchuk etc.) but I believe the length is different. I've seen notes that they can be adapted but I have no real info. The swaged ball at the gate end is about 7/16 diameter on my burb. This seems bigger than the commercially availble general purpose versions.
I could measure the partially shredded cable that I removed from mine but that dimension would only be approximate. Let me know if you need more info or if you find out anything as I need cables also. It's just that there are other issues I'm dealing with first.
Jon,
Search the panel and burb forum. There are a number of threads on this, including one discussing fabbing your own form standard hardware i belive.
Maybe one of the other bolters who have done this will chime in as well.
Ned
1951 Chevy 1-Ton Panel
Pictures of the restoration on Photobucket
RIP good friend.
Thank you both. I found a bolter that can do it once I measure up my truck he should be able to make them I will keep you informed
Thanks John and Ned!!
Jon
