7 members (SWEET, Donf, rfs56trk, sron48, 78buckshot, Wickedbass, JW51),
60
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 18 New Guy | | New Guy Joined: Feb 2012 Posts: 18 | Rebuilt speedo has been installed. Problem: No matter what speed driven, speedo only registers 5 mph.
Could my cable be suspect?
Thanks for the help.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes it could be, or the cable might not be fully tightened into the trans fitting or the lower cable end or driving gear in the trans could be buggered
Bill | | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | disconnect it from the trans and see if you can chuck up the "tit" inside the cable in your cordless drill and have a helper look at the gauge while you turn the drill slowly, then a bit faster, then you'll know if its a cable/speedo problem or drive gear in the trans case
....David
