1 members (RLB), 119 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
there is a drip coming from my 1950 3/4 ton steering box. I think it is the gasket on the side with the small adjusting screw. My question is can I remove that cover without disturbing all the ball bearings inside. Also do I have to remove that adjusting screw?
evac34 #840313 04/01/2012 4:48 AM
try filling it with John Deere Corn head grease- a self leveling grease that won't drip like gear oil...
GMC: Get More Cash...
1958 GMC
My Webshots photos
Yes, you can take the cover off without disturbing the internals of the box. Remove the locking nut, remove the cover bolts. Now, turn the lash adjuting screw clockwise while at the same time letting the cover move away from the box. The cover will come off once the lash adjuster is free from the cover.
Reverse the process for reinstallation and then adjust the steering box per the service manual.
DavidF #840366 04/01/2012 3:27 PM
Here is a steering box manual with nice pictures and directions.
http://chevy.oldcarmanualproject.com/booklets/5220mts01.htm
Joe
Joe H #840373 04/01/2012 4:14 PM
thanks for the info...hope I dont screw up the adjustments
evac34 #840434 04/01/2012 7:16 PM
By removing only the lower most bolt of the cover more that 90% of the oil will drain out and allow you to skip having to adjust it. The corn head grease will stay in a box that leaked previously.
You Tube
