1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | there is a drip coming from my 1950 3/4 ton steering box. I think it is the gasket on the side with the small adjusting screw. My question is can I remove that cover without disturbing all the ball bearings inside. Also do I have to remove that adjusting screw?
| | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | try filling it with John Deere Corn head grease- a self leveling grease that won't drip like gear oil... | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Yes, you can take the cover off without disturbing the internals of the box. Remove the locking nut, remove the cover bolts. Now, turn the lash adjuting screw clockwise while at the same time letting the cover move away from the box. The cover will come off once the lash adjuster is free from the cover.
Reverse the process for reinstallation and then adjust the steering box per the service manual. | | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | thanks for the info...hope I dont screw up the adjustments | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | By removing only the lower most bolt of the cover more that 90% of the oil will drain out and allow you to skip having to adjust it. The corn head grease will stay in a box that leaked previously.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
