0 members (), 54 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#840225 03/31/2012 10:05 PM
52 chev pick up in storage for 2 years. no spark off coil. What should I check?
see if the points are stuck closed. then look for spark at a plug wire not at the coil.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
I'd get a test light and start at the + battery cable and chase it until you get nothing.
1946 1/2-Ton Chevy
Sir Searchalot
Sir Searchalot
As Jimerit says, but you did not say that the starter turns the engine over? Assuming it does then the batt is good. Could be a distributor part, coil, ign switch, Plug wires., ignition wire. As has been said check the plugs to see if they spark, then head backwards.
You might try putting a dollar bill between the points and draw it through a few times while pinching the points. Many times the points will oxidize a bit if they sit for a while, and then no spark.
Kurt
Sir Searchalot
Sir Searchalot
We all used to use the stricker sand paper off of a book of matches.
