7 members (hdgeren, NJC, Wickedbass, Gone, Otto Skorzeny, rfs56trk, Peggy M),
53
Mod | | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 103 | My local locksmiths can't find a key code to cut an ignition key for me. My truck is a 1948 chevy. I've showed pictures of my ignition switch and no one even knew what it was. The numbers on my door lock are 6068 or possibly 6058. Ben | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The key codes for 1935-66 vehicles run from 8000 to 9499. Are you sure it's not 8909? If it is, the cut is 335422. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | The things cletis knows amaze me sometimes... how does he know them?
*woog ponders the size and depth of the cletis old chevy truck book/manual collection*
hmnn
-W
| | | | | Joined: Nov 2011 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 103 | Thanks cletis, I'll bet that is correct. I'll have a locksmith try that number. Ben | | | | | Joined: Nov 2011 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 103 | cletis, Your information was correct. I took those numbers to my locksmith and the newly cut key now locks and unlocks my door. You are awesome. Thank you so much for the help. Ben | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | |
