5 members (5 Window 9434, JW51, Ponchogl, Mike Roache, Charles in CA), 66 guests, and 1 robot.
Topics128,131
Posts1,056,722
Members48,454
#839450 03/28/2012 10:59 PM
does anyone know what the demensions of this gas tank would be from stock? how many gallons aprox???im wondering if i can tuck duel tanks from an old ford system with a balance or the stock manual splitter is my idea...any input would be great thx!
They take the same unique tank as the suburban. 15 gallons, I think.
One of the guys has plans for the Napco Specific tank. Look at www.napcopowrpak.com
The only help that I can offer is that I purchased a sender that was advertized as fitting a 55-59 NAPCO burb. It is 3/4 in. longer between the sender unit and the mounting flange and the horizontal section of the pickup is about 3/4 in longer. The part number on the box is 1518778. The mounting flange has two supports for the outside bit of the fuel pickup. The one that is used is two holes clockwise of the one that would be used for a pickup truck. John
