| | | Forums66 Topics128,135 Posts1,056,422 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 6 New Guy | | New Guy Joined: Mar 2012 Posts: 6 | does anyone know what the demensions of this gas tank would be from stock? how many gallons aprox???im wondering if i can tuck duel tanks from an old ford system with a balance or the stock manual splitter is my idea...any input would be great thx! | | | | | Joined: Apr 2009 Posts: 108 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 108 | They take the same unique tank as the suburban. 15 gallons, I think. One of the guys has plans for the Napco Specific tank. Look at www.napcopowrpak.com | | | | | Joined: Aug 2011 Posts: 24 New Guy | | New Guy Joined: Aug 2011 Posts: 24 | The only help that I can offer is that I purchased a sender that was advertized as fitting a 55-59 NAPCO burb. It is 3/4 in. longer between the sender unit and the mounting flange and the horizontal section of the pickup is about 3/4 in longer. The part number on the box is 1518778. The mounting flange has two supports for the outside bit of the fuel pickup. The one that is used is two holes clockwise of the one that would be used for a pickup truck. John | | |
