1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#83975 10/09/2007 10:34 PM
Hi,
I am bolting a 305ci in my 1942 chevy pickup.
Can anybod tell me the torquesettings that the pressureplate-bolts needs, the flywheel and the bellhousing-bolts need.
Or where I can find them.
All the best from Belgium.
Don't waste water, drink wine !
1946 Chevrolet 1/2-Ton Truck
#83976 10/09/2007 11:05 PM
H Online: Content
Flywheel-to-crankshaft bolts are 7/16" diameter, and torque to 65 ft/lb. Not sure what the newton/meter conversion is.
The pressure plate bolts are 3/8" diameter, and torque to 30-35 ft./lb.
Bellhousing-to-block bolts don't necessarily need to be torqued, but 30-35 ft./lb. will work for them also.
Good luck!
You're an angel, thanks !
Jan
