| | | Forums66 Topics128,052 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83975 10/09/2007 10:34 PM | Joined: May 2005 Posts: 96 Shop Shark | | Shop Shark Joined: May 2005 Posts: 96 | Hi,
I am bolting a 305ci in my 1942 chevy pickup.
Can anybod tell me the torquesettings that the pressureplate-bolts needs, the flywheel and the bellhousing-bolts need.
Or where I can find them.
All the best from Belgium. | | |
#83976 10/09/2007 11:05 PM | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Flywheel-to-crankshaft bolts are 7/16" diameter, and torque to 65 ft/lb. Not sure what the newton/meter conversion is.
The pressure plate bolts are 3/8" diameter, and torque to 30-35 ft./lb.
Bellhousing-to-block bolts don't necessarily need to be torqued, but 30-35 ft./lb. will work for them also.
Good luck! Jerry
#83977 10/10/2007 6:51 AM | Joined: May 2005 Posts: 96 Shop Shark | | Shop Shark Joined: May 2005 Posts: 96 | You're an angel, thanks !
Jan | | |
