| | | Forums66 Topics128,187 Posts1,057,212 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83973 10/09/2007 9:19 PM | Joined: Jun 2007 Posts: 95 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 95 | My butterfly valve on the exhaust is leaking. Spring works fine and valve opes and shuts. If there a repair for this? Would this make my engine miss when warmed up afer a mile?
J.D. Jordan
#83974 10/10/2007 3:13 AM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | It's a loose fit in the manifold. If it were to tight if would bind up from deposites. A little putt, putt from around the shaft is normal and is not gonna hurt anything and is probably even a good thing. Now keep in mind that there is a limit to how much of a leak is tolerable. Denny Graham Sandwich, IL
Denny G Sandwich, IL
