0 members (), 81 guests, and 5 robots.
Topics128,179
Posts1,057,160
Members48,465
My butterfly valve on the exhaust is leaking. Spring works fine and valve opes and shuts. If there a repair for this? Would this make my engine miss when warmed up afer a mile?
J.D. Jordan
It's a loose fit in the manifold. If it were to tight if would bind up from deposites. A little putt, putt from around the shaft is normal and is not gonna hurt anything and is probably even a good thing. Now keep in mind that there is a limit to how much of a leak is tolerable.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
