1 members (Samantha), 45 guests, and 4 robots.
Topics128,179
Posts1,057,159
Members48,465
About what would it take to drop a 5.9 or 6.7 cummins diesel in to a 60-66 GMC truck ?
I'm interested in building another dually 4x4 only this time with a diesel engine but i'll still want to run the manual tran's. . .
The plan:
5.9/6.7L cummins diesel, 6 spd manual tran's, gear driven transfer case, using a 60" cab to axle ford F-450 or F-550 chassie and axle's, dodge power plant cummins/6spd manual, gear driven transfer case 60-66 GMC cab. . .should be one tough truck. . . than you got solid engine solid tran's heavy duty chassie with spring suspension only reason for the ford frame and axle's. . .
Mike ohwell :confused_smile: :confused:
1962 GMC K3000, GMC-379 V6.
sounds like one hell of a vehicle except for the weak link,.. that six speed trans has been known to have syncro issues... just my $.02 from experiance. i have seen alot of them in harsh environments go out
~army truck
Sounds simple enough, new truck, old cab...
Why don't you look at some of the medium duty fords, they have the 5.9 Cummins in them stock.
What size truck do you want, 1 ton, 1.5, 2??
If you go with anything over a 1 ton it may be easier or better to use the original frame and add engine, trans, and axles.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
I saw a Cummins in an Advance Design (1-ton, I think) in a Shelton, WA truck show. I didn't crawl under for a look and didn't take photos. I wish I had.
H Online: Content
I've got a bunch of Onan/Cummins engines stashed away, ones that got pulled from UPS vans when they retrofitted to a different engine. They're already set up with a Chevy 292 mount system, and a stovebolt bellhousing like was used on late-50's trucks with the hydraulic linkage. It's also got a Chevy-spline 12" clutch so a SM-420 or a New Process 235 will be a bolt-on fit.
UPS used them, along with 292's and Ford 300's interchangeably in their high-cube vans. The Diesel is 120 HP at 3,600 RPM, with a turbo. The first one's going into a F-350 flatbed, replacing a 351 Windsor/C-6 automatic, and the next one will probably go into my 59 Burb with a 3/4 ton Dana 60 rear axle and a 3/4 ton IFS from a later-model Chevy truck.
