1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#83943 10/09/2007 7:51 AM
i HAVE BOTH MOTORS BUT CAN NOT DESIDE WHICH ONE TO USE THEY WILL BE REBUILT AND GOING IN A CHEVY TRUCK 1/2 TON IS THERE MUCH DIFFERENCE IN POWER ON THEM '
WHICH WAY TO GO........
#83944 10/09/2007 1:00 PM
ODSS Lawman
ODSS Lawman
No,
Being a Chevy truck, the 261 will fit without any mods to the front engine mount. Also, how do you plan to rebuild? I sent my 261 to JASPER and had it rebuilt, took only 3 weeks and cost much less that a buddy who had a GMC engine rebuilt.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
#83945 10/10/2007 6:48 AM
I can't speak to the power question, but the GMC was the hot rodder's favorite years ago.
The GMC is also made of a better alloy and is likely to last longer. Though I'd be surprised if you'll drive the truck enough miles to wear either motor out once its rebuilt properly.
#83946 10/11/2007 5:23 PM
The jimmy has a better combustion chamber design, and the valves go straight up and down instead of being cocked like in the 235/261. The good thing about the 261 is that intakes are cheaper and the block is shorter.
If clearance isn't a problem, I would go for the GMC.
I'm replacing my 261 with a GMC but its a 302. There's no contest there. The GMC engines cost more to rebuild than the 261, at least in the US.
Paint & Body Shop moderator
#83947 10/14/2007 7:02 AM
GMC 302 ? must be the old inline engine ?
1962 GMC K3000, GMC-379 V6.
#83948 10/14/2007 6:25 PM
Hi, I have a '52 GMC panel that had the 270 in it when I got it. The firewall was already modified for clearance, it's a long engine. The other option would be to remove the fan, move it forward and go with electric fans.
Royzell
#83949 10/15/2007 2:13 AM
Quote
Yup
1947 Chevy 6400 Wrecker
Old Stovebolts don't leak oil
They just mark their territory
#83950 10/16/2007 4:03 AM
I am partial to the GMC myself. They are a better overall engine. Full pressure oil system, heavier rods, rocker arms were stronger, you may even be able to punch out that 270 to a 302. There are some old hot rod books that lay out more info in terms of advantages and such. GMC will cost more to rebuild for sure.
52 GMC Suburban...52 Chevy 3/4 ton...49 CHevy 1/2 ton Rod...49 GMC 1/2 ton retro rod project
#83951 10/16/2007 10:19 PM
GMC's cost quite a bit more to rebuild, unless you happen to only need stock internals. Then, you can buy NOS military parts (pistons, bearings, whatever), and they are pretty reasonable. If you want custom pistons or cams be prepared to pay.
