Brrrr
place holder
2 members (Sjm, Wisner955), 95 guests, and 2 robots.
Topics128,271
Posts1,058,417
Members48,485
My GMC 248 came without many of the bolts I will need to put if back together. Also the top radiator hose inlet / thermostat housing is missing. I've done some looking and American Classic Truck Parts had a set of bolts but it was supposedly for a 235 Chevy. Same with the top radiator hose inlet / thermostat housing. My question is are these interchangeable to the 248 or am I outta luck?
I don't know if the bolts are compatible but I hardly think you are out of luck. As far as I know GMC doesn't make their own bolts and I am certain that bolt manufacturers would not make bolts that are exclusive to any particular engine. In other words I am certain there is a lot of compatibility.
I know the GMC rad has the hole on the side of the tank whereas the Chevy hole is in the centre. If that makes the thermostat housing different I could not say.
There is a good GMC truck site on the web and they could probably tell you more and they have a swap section where you might find the housing.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
