3 members (Nick in Manitou, J Lucas, klhansen), 106 guests, and 3 robots.
Topics128,088
Posts1,056,002
Members48,430
#839032 03/27/2012 11:24 AM
does anybody know what the factory gauge sheet metal was on these trucks?
Dave:
Depends on the panel. Outer body panels are generally 20 guage, bed panels are generally 16 guage and floor pans are generally 18 guage. I have a caliper from Harbor Freight with a chart inside my MIG welder that converts inches to guage. That's how I came up with the above.
regards,
Steve
New Orleans
sclor #839285 03/28/2012 5:13 AM
You may need to purchase the next size thicker at the iron shop because they sell steel these days like they sell 2x4s. Your safest way to get what you need is the measure your piece you are replacing and then measure the choices at the iron shop and find the one that measures the closest.
65 K10 Longbox Fleetside Big Back Window Custom Cab
65 K10 Flatbed
Old School Parts 60-66
(208)946-6173
[email protected]
66Suburban #839290 03/28/2012 5:56 AM
If you go and get a sheet metal gauge you can measure the correct thickness of your metal just be sure if you cut out a piece to file the edge so you can get the right thickness. My 62 C-10 floor is 18 gauge along with my rocker panel and replacement door post.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
Don G. #839291 03/28/2012 6:01 AM
Depending what you are going to do with the steel Hot Roll is more workable than Cold Roll but Cold Roll is stronger than Hot Roll hope this helps. I really havent noticed any change in the thickness of the sheet metal out here in Calif. but now that you mention it I will check for the thickness.
62Blue
Don
62Blue
62Chevy in progress
