7 members (Otto Skorzeny, DHedrick, TexasFarmTruck, Joe H, Sedgewick, Charles in CA, crenwelge),
153
Mod | | | Forums66 Topics128,282 Posts1,058,496 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 40 | does anybody know what the factory gauge sheet metal was on these trucks? | | | | | Joined: Jan 2007 Posts: 93 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 93 | Dave: Depends on the panel. Outer body panels are generally 20 guage, bed panels are generally 16 guage and floor pans are generally 18 guage. I have a caliper from Harbor Freight with a chart inside my MIG welder that converts inches to guage. That's how I came up with the above. regards, Steve New Orleans
| | | | | Joined: Feb 2011 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 52 | You may need to purchase the next size thicker at the iron shop because they sell steel these days like they sell 2x4s. Your safest way to get what you need is the measure your piece you are replacing and then measure the choices at the iron shop and find the one that measures the closest.
65 K10 Longbox Fleetside Big Back Window Custom Cab 65 K10 Flatbed Old School Parts 60-66 (208)946-6173 [email protected]
| | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | If you go and get a sheet metal gauge you can measure the correct thickness of your metal just be sure if you cut out a piece to file the edge so you can get the right thickness. My 62 C-10 floor is 18 gauge along with my rocker panel and replacement door post. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | Depending what you are going to do with the steel Hot Roll is more workable than Cold Roll but Cold Roll is stronger than Hot Roll hope this helps. I really havent noticed any change in the thickness of the sheet metal out here in Calif. but now that you mention it I will check for the thickness. 62Blue Don
