5 members (Bill Hanlon, LAROKE, rfs56trk, Maybellene, klhansen), 140 guests, and 1 robot.
Topics128,034
Posts1,055,544
Members48,425
#838750 03/26/2012 2:54 PM
hi guys im looking for some carbs to put
on a triple offenhauser intake...
the engine is a 1955 235 with 3836848 heads
i have no idea what carbs to run so your
help is greatly appriciated
regards
chally #838763 03/26/2012 3:33 PM
To do what?
panic #838767 03/26/2012 3:49 PM
to provide a air and fuel mixture to the engine? ohwell
just kiddin guess i could elaborate¨....
the truck will be a cruiser around town and mileage is not
an issue i just want to know the usual suspects when having
triple carb setups as these are new to me... one barrel two, barrell carter holly weber????? preferably a cheap/reliable setup
chally #838782 03/26/2012 4:41 PM
GM engineers figured out that the stovebolt engine needed a single 1-barrel carb. They made millions of them that way, and they worked well. Their only mistake was thinking they could build a better carburetor than Carter. Use the right sized Carter carb, bolt it on, and drive. Putting two or three carbs on where one is all that's needed is an exercise in futility or stupidity- - - -take your choice!
i was afraid of that answer as i heard that the three carb setup
is overkill...it just looks so darn cool!
anyone have a dual or triple setup you feel works well?
pleas share!
chally #838798 03/26/2012 5:15 PM
Use a 3-carb manifold and put blind gaskets under the end carbs. The dummies will be impressed by the cool factor, and the engine will still run right. BTW, it's nearly impossible to fit a 3-carb manifold onto a truck- - - -firewall and shift linkage interference, and some braces in the way on some models.
well the world is full of dummies.....
thanks for the heads up on the fitment isuess...
chally #838863 03/26/2012 9:33 PM
so Hotrod who and where can I get a 3-carb manifold for a 250 ? I like your Idea of blocking off the 2 outer carb
1938 Gmc 1/2 ton
chally #838877 03/26/2012 10:02 PM
Corvettes had 3 carbs!!!
DiGeM #838902 03/26/2012 11:43 PM
The problem with running 2 dead pots is that the mixture distribution is worse than the stock manifold - the #3-4 cylinders runs richer than the #1-2 and 5-6. This is not an adjustment and can't be "jetted out".
This also holds true for progressive linkage with all 3 working - the center pair is too rich. The cure is surgery inside the manifold, adding a ditch across the runner entrance etc. No, there's no diagram or instructions.
If you run all 3 simultaneous, be prepared for poor response and poor mileage. Use the smallest matched carburetors you can. If you can fit Rochester Model B, the ones used on the early Gen-3 194" L6 are even smaller than the 216" Gen-2.
panic #838922 03/27/2012 12:59 AM
I totally agree about poor fuel distribution on a 3-carb manifold with two dummy carbs mounted. We used to tinker with fuel distribution on multi-carb small block V-8's by running thermistors in the header tubes on the dyno and tweaking port shapes and jetting until the exhaust port temperatures started to match up under load. For an engine that's mostly designed to win trophies at the local show n' shine, putting a couple of dummy carbs on a 3-carb manifold is a quick and dirty method of getting to and from the show without a lot of backfiring and underhood fires. It's nowhere near as good as a properly set up original fuel system.
panic #838942 03/27/2012 1:53 AM
A 2 carb manifold with 2 smaller carbs, like the 1.5" bore Carter W-1s, or The Carter WAs like Hudson ran, is better for street use.
Read this: http://www.thecarburetorshop.com/Dual1barrelcarbs.htm
YOu'ld need to find some really small carbs to make a triple work on the street, and they don't really fit anyways, unless you want to modify the firewall.
1945 1.5-Ton Chevy Big Bolt
Maynard
More pix of the old truck
Drydock #839041 03/27/2012 12:56 PM
thanks for the input fellas i went with a dual fenton and
purchased carbs from langdons.... heard nothing but good feedback
from others who has gone this route
chally #839108 03/27/2012 5:20 PM
This thread has piqued my curiosity... What is the general opinion of a single, progressive 2-bbl carb on an otherwise unmodified 216? I was thinking of the weber 32-36, in hopes of a little more economy at low cruise and a little more power wide open. Is this a good idea? Or would I need a larger 2-bbl to make it work?
Highflyer #839150 03/27/2012 9:29 PM
My curiosity got piqued in a different way: how to have 3 carbs and maintain driveability.
I suppose one could make an elongated carb spacer from aluminum plate mounted on the stock manifold that the dummies mounted to. It could even have some fins or other details to obscure/disguise the stock intake. Any other ideas out there?
You Tube
Curt B. #839234 03/28/2012 2:20 AM
Buy an Austin-Healey 3000 MK II- - - -it's got 3 side draft SU carbs on a 3-liter inline 6 already.
8
8 Offline
Or, maybe a Corvette intake with the Carter YH's. They come up on e-bay from time to time. If I had the money... ohwell
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
