| | | Forums66 Topics128,127 Posts1,056,678 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 22 New Guy | | New Guy Joined: Sep 2007 Posts: 22 | Did Chevy change the setup/rigging of the emergency brake system between the years 1947 and 1952 on their 3100 series of 1/2 tons?
I have a 3100, '52 1/2ton and need the whole set up from the foot stomper to the brake release. I might be able get parts off a 47/48 truck if they're the same. I have one schematic of the e-brake system, but it's a drawing and hard to see what it really looks like.
The '52 has drum brakes in the back.
Thanks in advance. Marc - "Bigeasy" | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Marc, In 1947, the parking brake was on the transmission (both the 3-speed and the 4-speed had floor shifters in 1947). In 1948, the parking brake "was activated by a pedal through the left side of the floorboard (allowing the driver to easily exit on the curb/passenger side - the exterior door lock is on this side). A new fender skirt (inner fender) was needed for the parking-brake pedal-mounting lever." From 1948-1954, the truck foot operated starter parts were almost all the same. The differences in a few parts are not significant for the foot-starter assembly assembly to work on all 48-55st manual transmission trucks. Some of the parking brake control parts differed between 1948-1955st. | | | | | Joined: Aug 2009 Posts: 163 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 163 | on my 47 1/2 ton the ebrake, or parking brake, handle is located to the right of the shifter and is a hand operated lever.
On a 48 the same lever is moved to the left of the clutch.
On a 52 you should have a foot operated style that mounts on the left side of the clutch pedal and a hand operated release lever under the dash that would be operated with your fingers.
Look for a set up from a 49 to 54. All the parts should interchange. I will check I should have the pedal and release rod. | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | The '48 has the setup you describe for the '52, 5/8 ton.
The '48's have the "three-on-the-tree" setup, while the '47's had a floor shifter. That's why they moved the e-brake to the left side and developed the foot engaged/finger released system. The '47 had the e-brake on a stalk near the floor shifter. | | | | | Joined: Sep 2007 Posts: 22 New Guy | | New Guy Joined: Sep 2007 Posts: 22 | The Stovebolt forum and you guys, are the best! Thanks! for the information. The parts I'm guessing on are from the '48. It's look to be what 5/8 ton was saying - foot pedal on floor to left of the clutch with a finger pull (small T shape grip) release handle mounted on the top side under the dash.
Thanks. | | | | | Joined: Aug 2009 Posts: 163 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 163 | I seen a 48 with the hatchet style hand brake not foot actuated thats why I described it that way. Sorry if I was wrong.
| | | | | Joined: Sep 2007 Posts: 22 New Guy | | New Guy Joined: Sep 2007 Posts: 22 | No problem. I have a '46 Panel Truck and the e-brake is a pole right next to the shifter too. But the picture I have from the donor '48 is a foot pedal e-brake with the T pull release up under the dash. All good - helped me. | | | | | Joined: Sep 2007 Posts: 22 New Guy | | New Guy Joined: Sep 2007 Posts: 22 | Tim's diagram, and your photos blow me away. The diagram looks to be the best thing I've seen and looks to be the ticket - closest to what the slots in the floor look like they would handle.
Where did you pull those parts up so fast? Dang! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Brad,
As always, thanks for the education.
