0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#839043 03/27/2012 12:57 PM
I have a '48 chevy 2 ton with a lift bed. Does anyone know what oil to use for the hydraulic lift?
Hydraulic oil you can get at any farm store.
Bruce
My Trucks
Stuff I Collect
Nearly all the hydraulic oil available commercially today has antifoam, antiwear, and detergent additives. That being said I would only add the amount of oil necessary to make it work unless you have thoroughly cleaned and rebuilt the system. Those additives can cause problems in an old contaminated hydraulic system so buy straight hyd oil w/o additives if you can find it. (good luck) If not you may be able to find 5W non-detergent motor oil as an choice. The lighter (re: thinner)n the oil the better. I doubt you intend to use it much anyway.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Thanks guys for the info.
